Cold Minnesota Basement Probs
tclemens1 | Posted in Energy, Heating & Insulation on February 13, 2018 12:19pm
I purchased a home back in october and have learned that the finished basement is very cold.
Peeking into an access panel, I found that there is no insulation between the drywall and foundation.
Is there anygood way to insulate besides tearing the drywall down and filling that air gap?
  1. florida | Feb 13, 2018 12:43pm | #1
    No. Your best bet would be to start over and have closed cell foam sprayed on.
  2. DanH | Feb 13, 2018 02:19pm | #2
    Drywall is cheap and easy to remove/replace.
    But check for air leaks first, especially along the rim joist.
  3. Norman | Feb 13, 2018 06:33pm | #3
    Windows?
    What kind of shape are your basement windows in?
    I replaced about a dozen 1926 basement windows in my Chicago bungalow with modern vinyl replacement windows and the basement air temp improved by 10*.  This is still with zero insulation on the walls.
    If your windows are as numerous and as bad as mine were, this is an easy fix.
    Good luck.
