Collar Ties on Hip Roof?
NCtim | Posted in Construction Techniques on September 13, 2005 02:40am
What are the rules for collar ties?
I’m building a small hip-roofed screened pavillion that will be 16 X 16 with 2-foot eaves. I want it to open all the way to the hip rafters in the center of the ceiling. The construction will be 6 X 6 pt posts every 4 feet oc with a 4 X 10 header let in all around the perimeter.
Do I need collar ties? My instinct says yes but I’ve not seen this in any of the photos I’ve looked at.
Thanks, NCtim
  1. Piffin | Sep 13, 2005 03:59pm | #1
    no
    First - are you falling victim to the common misunderstanding that a rafter tie is a collar tie?
    Collar ties are used in the upper third of the roof frame about ever four feet to resist upward hinging in a violent wind that can take the ridge apart other wise. Code required in some southern tornado prone states
    Rafter ties are used in the lower third of the rafter and resist outward thrust of gravity on the walls. For your structure, it is possible to do without them, but the hips should be stout enough to handle the laods. There is no ridge in a square hipped building, so the load that would normally be carried by a ridge or resisted by rafter ties is going to be transferred to the corner posts, so all your connections there will have a lot ofshear on them
    1. NCtim | Sep 13, 2005 09:21pm | #4
      Thanks. I appreciate everyones' input. I guess what I originally meant was rafter ties because they wouldn't really be collar ties. I was hoping you all would say I didn't need them because of the visual distraction. That and the span is small so I didn't think I needed them. Our building code here in NC isn't very clear on this issue, I can interpret it just about anyway I want on this issue.
      NCtim
      1. mossywyatt | Sep 15, 2005 03:26am | #6
        I think that the top plates of the wall are the rafter ties so you should make all of the connections from hip to hip strong including hip to plate
        wyatt
    BossHog | Sep 13, 2005 06:08pm | #2
    Ditto what Piffin said.
    But check your local codes - You never know what they might say.
    Congressmen have been bought and sold so many times they should have bar codes.
  3. GHR | Sep 13, 2005 06:10pm | #3
    It depends on how you do your engineering and your detailing.
    Each side of a hip roof constrains the other sides so you don't need ties to hold the upper section together.
    The plates at the top of the posts and the plywood hold the lower section together.
  4. calvin | Sep 14, 2005 02:50am | #5
    This was engineered in a public building, but it seems to prove that it can be done.  Certainly does look good.
    Quittin' Time
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
