This may be intuitive or a dumb question, but if I plan on using
an acid stain technique to color a conrete floor, should I NOT
use fibermesh concrete? The fibers will probably show, but
does this detract or add to appearance?
Listeners write in about condensing dryers, giant gears, and saggy doors and ask questions about chimney safety, black windows, and rot-resistant assemblies.
not fiber. I don't know your experience base with this, so I'll just say make darn sure you do all the prep, have it clean and dry, and get absolutely nothing on it until the stuff is done. At $120 a gallon, it's expensive enough without mucking up the concrete.
"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
