In a basement room, I would like to color the concrete slab rather than painting it or putting down a floor covering. Is there any process that can be used to stain a cured slab?
Thank You
Thank You
This compact detatched accessory dwelling has an efficient layout with a vaulted ceiling that enhances the sense of space.
acid stain sounds perfect. Go to http://www.acid-stain.com or decorative concrete (http://www.decorative-concrete.net/) to learn more. There is a very good message board at acid-stain.com.
Paula
Thank You!_DAVID R. WARNER, JR
