column use in additions
| Posted in General Discussion on May 12, 2000 02:28am
My question involves the proper placement of aluminum columns for a gable roof over a stoop(rough size is 5′ I 7′). The plan calls for the use of doubled up 2×8’s for the beams and 2 columns at the outside corners. The 6″x8′ AFCO columns give no indication as to the placement of the beams on the capital. It is my opinion that the beams should sit directly over the outside circumference of the shaft, not only will this give direct transfer of the weight from the roof it will also give the correct look(beams set back from the outside edge of the capital). Do you agree? I look forward to any and all advice. JN
  1. Guest_ | May 09, 2000 04:53am | #1
    john,
    With one column on each corner, the normal placement of the column would be at the center of each beam on the corner. That is, the center of the column would be at the center of the framing material on the corner. Of course, other placements are possible, but this one is typical around here.
    Red dog
    1. Guest_ | May 12, 2000 02:28pm | #3
      *John:What you have thus far is correct. Also, think about building up the width of the supported beam to, say, 4.5" so that there will be more bearing surface on the column. Also, remember to plan the placement of the beam/roof over the porch to allow for the plinth (column base) to sit fully on the supporting surface.
  2. john_nicholas | May 12, 2000 02:28pm | #2
    My question involves the proper placement of aluminum columns for a gable roof over a stoop(rough size is 5' I 7'). The plan calls for the use of doubled up 2x8's for the beams and 2 columns at the outside corners. The 6"x8' AFCO columns give no indication as to the placement of the beams on the capital. It is my opinion that the beams should sit directly over the outside circumference of the shaft, not only will this give direct transfer of the weight from the roof it will also give the correct look(beams set back from the outside edge of the capital). Do you agree? I look forward to any and all advice. JN
