I’m looking to expand my knowledge of commercial doors and hardware including types, applications and installation techniques. My work now is about 99% residential so I don’t have much opportunity to learn on the job. Can anyone recommend a good book, like a text they’d use in a formal program or a good place to find such information? All of the books I’ve been able to find online deal mainly with wood door frames in residential applications. The search of this forum hasn’t produced anything for me yet. Thanks a bunch.
For a stable, flat, and squeak-free floor, you'll find that most new products are OSB.
Here's a place to start,
http://professional.schlage.com/literature/literature.asp
You can learn alot from their catalogs. Basic commercial is their L series, also D, and A series.
This is their parent company. You can look into exit devices, another common commercial piece of door hardware. (also known as a "panic bar")
http://securitytechnologies.ingersollrand.com/pc_doorhardware.asp
Look at door closers too...buic
Edited 5/23/2008 10:42 pm ET by BUIC
PTP,
In 1977 when I was a first year apprentice, I was assigned to help with the door hardware on a large school. I ended up drilling and tapping steel frames for parallel arm closer brackets on a couple hundred door frames set in block walls.
I've been learning ever since, and for the last 10 years have been in charge of maintaining doors and hardware in a large medical center.
The Door & Hardware Instituite has many technical publications that address this subject. http://www.dhi.org/publications/
Another thing you might try is contacting Ingersoll-Rand at
6230 Bury Drive
Eden Prarie, MN 55346
Tel: 952-893-8074
Fax: 952-893-2389
They have classes that are brand specific for Schlage locks, LCN closers, Von Duprin exit devices, and Steel Craft door frames.
i think just about any door will do,as long as it has a fire rating stamp. for hinges, closers tracks etc. try hafele, crowder, rixon (maybe rixson). there's some nifty hardware out there that you don't see in subdivisions, that's for sure.
