Common fir boards for a raised garden bed?
ErikU | Posted in General Discussion on June 24, 2010 04:36am
Our company purchased some used pallet racking recently.  As part of the deal we also inherited a hundred or so common fir 2 x 10’s and 2 x 12’s approximately 44″ long.  We have no need for them here, so I thought they might be useful for raised veggie garden beds.  The problem, of course, would be applying a preservative that would be non toxic and long lasting.  Is this a pipe dream?  If not, can anyone suggest a material to use?  A trip to my local Lowe’s didn’t turn up anything.  Thanks!
Erik
  1. FHB Editor
    rwotzak | Jun 24, 2010 04:58pm | #1
    Fir alone worked fine for me
    Erik,
    I just pulled up some raised beds that I built out of common 2x12s about 7 years ago and they were still solid about half way through. If you got the boards for free, I wouldn't hesitste to use them as is, and just know they're not going to last forever. Mine would have probably been servicable for another 2 or 3 years at least.
    Of course the type of soil that's underneath them will have some effect. if you're on poorly draining clay you might not have as much luck as I did with my base of sandy soil. Still, if the wood didn't cost you much...
  2. DanH | Jun 24, 2010 07:51pm | #2
    I'd just coat them with some sort of oil finish and watch 'em rot.  Should last several years, and regular treated doesn't last much longer in that situation.
  3. andybuildz | Jun 24, 2010 11:49pm | #3
    Ditto to what they all said...
    I did the same..just used pine planks till they rotted and became compost.
    Kinda goes along the lines of not using chemicals on your veggies..1/3 goes to the bugs, 1/3 to eat and 1/3 given away..
    http://i415.photobucket.com/albums/pp238/dangerbrain2000/organic.jpg
  4. rdesigns | Jun 25, 2010 09:31am | #4
    By the time they rot, you'll either give up gardening or be ready to change your methods and layout.
    Meantime, no worries about chemical contamination from the boards.
