I am preparing to put a deck on my house. It is modest size, 20’x24′, and one level. I have built decks before, but I have never used the new composite decking material that is now available. There are many manufacturers and styles to choose from and I’m having a hard time figuring out which one is the best quality. Does anyone have any input on what brands are good and which ones to stay away from? Any advice for a guy who has not worked with this material before? Anything you can pass on is greatly appreciated!
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
Trex is the best value for your money. It sells here for about $1.60 per foot.
Trex is easy to work with,it is quiet to walk on, and installs well with Fastap poly 2 fasteners.
I've installed the plastic "carefree" and "Ewood" and I don't care for either. The carefree expands and contracts about an inch in the course of a day. Ewood melts on your blade when you cut it and the space between the boards is 1/2".
Bob
I have done two large projects using Timbertech, tounge and groved ( hidden fasteners) I would use it again and again. About $5.00 sq ft for decking and an outrageous $5.00 lin ft for the fascia board. Both projects are about 3 years old, the stuff looks great, have had no problems, easy to install, simple to maintain. I just add a cup of swimming pool chlorine and half cup of trisodium phosphate to gal of water, mop it on, rinse it off with a hose. The results are tremendous. Check out their web site.
Marko,
I know that your post is a month old but I just saw it. I think Trex is the way to go. If you want some tips on installing it do an advanced search for post #20350.2
