Composite deck repair
Virus | Posted in General Discussion on November 4, 2009 03:35am
Is there a good product to fill a several 1/4 -1/2 inch holes (some completely thru)in composite decking? I’d like to reuse some pieces but in order to remove them from other location, several screw holes needed to be enlarged to access stripped screws.
  1. djh | Nov 04, 2009 03:41am | #1
    Virus,
    I've seen plugs cut and glued in for a decent look.
    Don
    1. Virus | Nov 04, 2009 03:48am | #3
      Thanks sounds reasonable. Has anyone mixed composite shavings with some kind of adhesive/caulk and stuffed in hole?
      1. Waters | Nov 04, 2009 03:55am | #4
        That sounds 'high effort -- low reward'Go find that router kit--it's a chance to buy tools!
  2. Waters | Nov 04, 2009 03:45am | #2
    Whiteside has an inlay kit for your router.
    It's an 1/8" spiral bit and a collet with removeable tip that will cut perfect inlays inside any pattern you want.
    I often use it to make plugs to fill bolt holes and whatnot in salvaged boards.
    Kit costs about 40$ I think.
    Should work fine in composite decking--make the plug of same material and it will be invisible.
  3. TomE | Nov 04, 2009 06:37am | #5
    Like Don sez
    Plug cutter (tapered type) and correctly sized drill bit.
    Edited 11/3/2009 10:38 pm ET by TomE
