anybody know any thing about networks and XP. I had to get my password back, which I did. but now it wont log onto the company network.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
Did U check if the workgroup is valid?
Quality repairs for your home.
AaronR Construction
Vancouver, Canada
Ok, fess up.
Who you trying to hack ?
Click here for access to the Woodshed Tavern
Reboot your pc and refresh the password. Have you scanned for the network to make sure its there?
Impossible to know with info given....what all has gone on that caused the initial problems logging into your puter...and what all has gone on since....and what the current symptoms/behaviors are. Current problem and resolution could be one or more of many potential faults/ errors or system settings....or even a problem with the NIC.
The simplest/easiest resolution *might* be to create a new restore point...and then do a system restore back to a date just before the problems began.
Cross your fingers.
