Conc Counter with Decorative Agg
brad805 | Posted in Construction Techniques on August 8, 2008 10:04am
I have the Neomix from Cheng, polisher and all the materials I need for my Concrete Counter trial.  I am awfully fussy, so I thought I best start with a trial that could be thrown away should I hate it.  I am planning to build a mould and cast face down since I fear my finishing skills would lead to far too much grinding.  I would like to use the decorative aggregates I have.  Is it best to add them into the mix or try to adhere them to the finish surface?  I read somewhere that a good start was to add 1/2lb of the dec aggs per cu ft, but that seems very very light after looking at a 1/2lb quan.
  1. FastEddie | Aug 08, 2008 10:37pm | #1
    If they are decorative, why would you want them buried in the bottom of the finished top?  I would spread them in the bottom of the mold before the mix goes in.  That way you get to adjust the layout to get the best finished look.
    1. brad805 | Aug 08, 2008 11:10pm | #2
      I was concerned they will float once I turn on the vibrator, but if that is how it is done I will give it a whirl.  I know any pieces (shells or other) that they embed are siliconed down.
      Brad
      1. [email protected] | Aug 09, 2008 01:55am | #3
        The other option is to mix more than one batch, with the decorateve aggregate in the first batch.
        Personally I would use a bit of wax to adhere decorative objects to the form instead of silicone.  I think any residual wax would polish in quite easily.
        1. brad805 | Aug 09, 2008 02:02am | #4
          glad I asked this Q.  thks
          Brad
  2. dovetail97128 | Aug 09, 2008 05:09am | #5
    108112.1
  3. ponytl | Aug 09, 2008 05:20am | #6
    if you find a piece of lexan for your mold ( i get and use old sign faces ...use the back side) leaves a very slick finish... i use johnsons paste wax (floor wax) as a release agent... i also use it to fill corners to a slight curve... it's also what i'd use to hold things in place i wanted to embed.....  if you have decorative aggregates the only way you'll expose them is thru grinding... so like was posted i'm make a decorative aggregate rich mix and place it first  (maybe 1/2" thick) ... then back it up with a standard mix....
    let us know how it turns out...
    oh yeah just cause you make a sample  doesn't mean you'll ever be able to make one just like it again...  i've never had 2 come out the same even when the mix came from the same batch
    p
    1. dovetail97128 | Aug 09, 2008 05:35am | #7
      Glad to see you post here. I tried search for some of your comments on this work and couldn't get any to pop up. Edit for spelling .
      Edited 8/8/2008 10:35 pm by dovetail97128
    2. brad805 | Aug 11, 2008 06:58pm | #9
      Thks for the tips.  Yeah I suppose they will not turn out the same.  I will call it practice to make sure I get the mixing and polishing right.
      The more I think about it the 1/2" batch with the dec agg makes the most sense.  It would take a lot of time to glue the individual stones down.
      Brad
  4. Waters | Aug 10, 2008 06:25pm | #8
    http://forums.taunton.com/tp-breaktime/messages?msg=101058.1
    Hi brad.  Lots of info shared in this thread.  Don't know if you've seen it.
    I'm working away from a computer during the week but I'll check how you go next weekend.
    Listen to Ponytl-got some great tips from him.
    Cheers,
    Pat
    1. brad805 | Aug 11, 2008 06:59pm | #10
      Couldnt find that one.  Big thanks.
    2. Waters | Aug 17, 2008 06:55pm | #11
      How's it coming?
      that thread, again - 101058.1
      If you still can't link into it, use the search function for 'concrete counter' and you'll find a week's worth of reading.
      Pictures?
      Thx,
      Pat
      1. brad805 | Aug 25, 2008 07:13pm | #12
        I tried sprinkling the dec agg on the mold surface and it turned out to be a bad idea.  I had a few spots where the decrative aggs were a little too thick so some flecked off when I flipped the piece (instant fill spot) plus it didnt bind very well with the concrete due to the small piece sizes.  After a bit of work I am amazed I salvaged the piece.  A bit of the slurry and some patience and it is going to be a good table top.  I will post a pic when it is done (not much).  All in all a great learning excercise.
        How do you edge your pieces?  I know you silicone the corners to make the profile but you must have to clean it up a bit.  I used my polisher, but I am finding that this is pretty hard on the discs.  I have seen the ones the granite guys use, but I thought you might have another idea.  Your rotary hammer tip idea was great.  I am going to use my air one on the next cast.
        Mold #2 is ready to go.
        Brad
        1. Waters | Aug 26, 2008 06:53pm | #13
          I tried sprinkling the dec agg on the mold surface and it turned out to be a bad idea.  I had a few spots where the decrative aggs were a little too thick so some flecked off when I flipped the piece (instant fill spot) plus it didnt bind very well with the concrete due to the small piece sizes.  After a bit of work I am amazed I salvaged the piece.  A bit of the slurry and some patience and it is going to be a good table top.  I will post a pic when it is done (not much).  All in all a great learning excercise.  Yeah, Ithink it's better to put it in the mix--perhaps a small mix just to line the form--for the surface.  Vibrate well, then lay in the rest iwth less, or without the dec. agg.
          How do you edge your pieces?  I know you silicone the corners to make the profile but you must have to clean it up a bit.  I used my polisher, but I am finding that this is pretty hard on the discs.  I have seen the ones the granite guys use, but I thought you might have another idea.  Your rotary hammer tip idea was great.  I am going to use my air one on the next cast.  That little bead of silicone that I put in my molds creates a perfect little radius.  I try to avoid it when I finish the top b/c it's so clean.  For polishing and finishing, you need the 4" diamond wet pads, run on a variable speed grinder--down @ less than 3,000 rpm.  Is this what you're using?  Those are really it.  I wish they made that outfit bigger though.  4" is so small.  There's a seller on ebay that will send you what you need for less than 50$  Good luck!
          1. brad805 | Aug 26, 2008 11:54pm | #14
            Truth be told, I didnt find all the tips for vibrating before casting the trial piece.  That added to the slurry part of the excercise.
            I did buy a flex polisher and am looking at some diff polishing stones for edging.  I polished the edges with the discs
            Pics of my setup are attached if anyone is interested.
            Brad
            http://s272.photobucket.com/albums/jj176/Brad805/?action=view&current=4338fc89.pbw
