concealed hinges for trap door
grumpy | Posted in General Discussion on April 3, 2006 03:52am
I’m finishing up the punch list on a home that has a trap door in the office floor that leads to a storm room. I was asked to hinge this door as well as install flush finger rings the hinges are to be concealed. This door is made up of 3/4 subfloor and 3/4 hardwood flooring. I am lost as to what type of hinges to use or how to do it. I have looked at various chest hinges at he local big box store they only open from 65 to 90 degrees. I’m thinking about the thickness of the door wouldn’t it have to raise up first then swing open. thank you for any tips,  ideals. thank you again  terry
  1. Oak River Mike | Apr 03, 2006 05:10am | #1
    grumpy,
    Do a search for SOSS hinges.  I used them on the hidden door in my house and they work great!  Not cheap mind you (I think I paid $50. for a pair?) but awesome pieces of mechanics.
    Mike
  2. DanH | Apr 03, 2006 05:15am | #2
    Yeah, SOSS. They come in a bunch of sizes, from jewelry box size to large door size. You'll still need substantial stops all around, of course, to withstand the weight of walking on the door.
    happy?
  3. BruceCM | Apr 03, 2006 05:26am | #3
    Or you could put finger pulls on each side of the trap door and do away with the hinges...just set the door aside when accessing the crawl space.
    BruceM
  4. ponytl | Apr 03, 2006 05:41am | #4
    i once used some MG midget trunk hinges... they bolt flat to a surface (underside)  even some auto door hinges might work...  just a thought
    p
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
