Concrete Basement Floor Heaving up
| Posted in General Discussion on November 18, 2004 02:31am
I have been to several houses and a community center and there were areas of the concrete floor that has heaved upwards by as much as 5 or 6 inches.
What would the cause be? I am afraid that If I just reconcrete that section without addressing the underlying problem,we may have to fix that defect again.
Great magazine and discussion group.
  1. brownbagg | Nov 18, 2004 02:43am | #1
    swelling clays
    1. TomM1 | Nov 18, 2004 03:25am | #2
      What causes the clay soil to swell?
      1. blue_eyed_devil | Nov 18, 2004 03:31am | #3
        H2O.
        blueWarning! Be cautious when taking any framing advice from me. Although I have a lifetime of framing experience, all of it is considered bottom of the barrel by Gabe. I am not to be counted amongst the worst of the worst. If you want real framing information...don't listen to me..just ask Gabe!
    2. TomM1 | Nov 18, 2004 03:39am | #4
      Would the fact that the weeping tiles have failed cause or worsen this problem?
      1. Piffin | Nov 21, 2004 12:49am | #5
        Yes
      2. Sasquatch | Nov 21, 2004 01:56am | #6
        Since you don't have any profile info, I can't tell what part of the country you are in.  If the facilities are subject to freezing conditions, there is a possibility that the expansion that occurs when water changes state to ice could also be responsible.  Most basement floors should be designed to be floating pads, resting their edges on the inside of the footing, and able to rise up in the event of an unforseen expansion. Les Barrett Quality Construction
  2. Hubedube | Nov 21, 2004 02:01am | #7
    HYDROSTATIC PRESSURE
  3. TrimButcher | Nov 22, 2004 04:49pm | #8
    Hydrostatic pressure indeed.  Are you sure that these buildings weren't built on an underground spring? Perhaps a deep-buried, large sewer pipe that has cracked/opened? Been known to happen.
    Regards,
    Tim Ruttan
    1. HammerHarry | Nov 22, 2004 05:48pm | #9
      In the area I live in, one of the contractors just bought back his second house.  First one he had to buy back, homeowner noticed the basement floor elevation  changed by, oh, 4 to 6 inches.  After much dithering, homeowner hired a lawyer, and contractor bought back the house.  After removing the basement floor, and putting in some halfassed drainage, he re sold the house.
      The latest one, I see that he has removed one whole basement wall; the back of the house is up on steel beams while he rebuilds the basement.
      Oddly enough, in the houses built by other contractw who use proper perimeter drainage around the outside of the foundation, there are no water problems.
  4. mike11 | Nov 27, 2004 12:50am | #10
    i bielieve i can solve your problem and keep it solved, non intrusive, not waterproofing, used by military, us treasuary. govts, etc.
    [email protected]
Picture-Perfect Pergola
