Concrete cracks and expansion joints
etherhuffer | Posted in General Discussion on July 5, 2007 07:25am
I have some old disintegrating expansion joints. How to replace them? I thought that a silicone caulk type product would stick to the edges and also stop weeds. Cracks? What to do?
www.etherhuffer.typepad.com
  1. dovetail97128 | Jul 05, 2007 09:00am | #1
    Look here for SIKA products.
    I have used them and they work.
    http://www.sikaconstruction.com/con/con-dealer/con-dealer-sealing.htm
    "Poor is not the person who has too little, but the person who craves more."...Seneca
  2. DaveRicheson | Jul 05, 2007 01:25pm | #2
    In addition to dovetails link you can also use Sonneborn SL-1 polyurethane, which you can find at the big box stores. Be sure to get some backer rod and use it to fill in the joint after you clean out the old material. You only want the new sealant to adhere to the two side edges of the joint, not the bottom. Any sealant will last much longer when installed the correct way. They are formulated to stretch in one plane only. When the bottom  (vertical) plane is adhered, the caulking will split and fail.
    I like the SL-1 product for cost, ease of use, and finished joint longevity. It self-levels, and with a little masonary sand dusted on it while it is still tacky, makes a nice looking joint.
    BTW, I think BASF now owns Sonneborn.
    Dave
    1. DanH | Jul 05, 2007 02:07pm | #3
      Further, caulk that is applied too thick will not adhere as well, even if it doesn't contact the bottom. The thicker (deeper in the joint) it is, the less it can stretch.
      1. etherhuffer | Jul 05, 2007 05:57pm | #4
        Thanks guys, good looking products. My 30 year old joints look very bad and grow weeds each year.http://www.etherhuffer.typepad.com
