I have seen polished concrete floors but they were all grey
Could you get a cremecolored polished concrete floor?
Simple air-sealing measures and spray-applied sealant lower energy bills and increase comfort without the need to tear the house apart.
I think generally this is done by pouring a relatively thin layer (1/2' to maybe 2") over a regular slab.
Basically you're talking about a very simple form of Terrazzo: http://en.wikipedia.org/wiki/Terrazzo
thanks dan, I was not thinking of terrazzo. I saw a floor in an architect's home. It looked like they polished the floor with some kind of epoxy, but it was dark grey. Not the cream color I was looking for.
Well, there's two varieties of "polished". One is ground with a heavy-duty floor sander, and the other is coated with an epoxy-like coating.
But to get color (that isn't just painted on), and especially to get a lighter color (vs just coloring the concrete), you need to have a layer of a lighter-colored material on top of the regular concrete. I think in some cases it can be applied as a powder on the wet concrete, but that produces a fairly thin (maybe 1/32 to 1/16") coating, and it can be hard to get the color even.
Also keep in mind that almost any color combination of stains, dyes, paints, tinted cement based finish coat, etc. can be applied to the surface and covered with a clear or not so clear coat of epoxy.
Honestly the sky's the limit!
Check out Acid Stained Concrete
See if that is what you were looking at.
I did my driveway about 10 years ago.
concrete floor
thanks, guys, I will look into this
Concrete stain
There are acid stains and water stains and any number of sealers. The products I use come from Westcoat. I've gotten excellent support from them. http://westcoat.com/ This is not an add. Just a recommendation.
You could spec the use of white cement rather than the usual gray portland cement. This will result in a significantly lighter color. You will want to see some samples beforehand to be sure it is what you want. You may have to do the sample yourself, or have your contractor do it. And, be prepared to pay a premium to the batch plant for making the mix. As far as placement and finishing, there should be no real difference.
I have not seen any other color either but isn't that rough raw look why we lovepolished concrete?
