Concrete over wood subfloor
Tannin | Posted in Construction Techniques on June 15, 2006 01:31am
I’m using PEX in floor heat for my new home. The floor is rated to accomodate 1 1/2″ of concrete to encase the PEX tubing. I have used 3/4″ tongue and groove plywood for the subfloor. I could call in a contractor to pour gypcrete over the PEX at a cost of about $4000. I have tried to buy gypcrete and similiar products to install myself without success. The cost of using concrete, which I could install myself, is about $800.
Do I need to use a bonding agent before I place the concrete? Should I provide a vapor barrier or treat the plywood first? Any help or references to placing  1 1/2″ concrete over a plywood subfloor would be much appreciated.
  1. gyros | Jun 15, 2006 02:45am | #1
    I usually fasten metal lathe on the ply first then radiant tubing,make sure you order concrete with max. 1/2 " aggregate .I did this to my own house 7 yrs ago with no cracks yet.
    1. Tannin | Jun 16, 2006 04:38am | #2
      Thanks. Did you have expansion joints at the doorways or was this one big pour?
      1. gyros | Jun 17, 2006 03:28am | #3
        I carefully cut expansion cuts ,if you can call them that 3/8 " deep in the doorways after the pour then grouted.
  2. blue_eyed_devil | Jun 17, 2006 04:26am | #4
    Why can the contractors get gypcrete and you cant?
    blue
    1. Tannin | Jun 18, 2006 11:34pm | #7
      The manufacture is telling me that I have to specially trained to use their product.
  3. ponytl | Jun 17, 2006 01:04pm | #5
    you might ck so pics i posted where i did 10,000 sf  of concrete over wood... lightweight concrete... over 4mil plastic...  i was 20 ft up from ground level so i used a pump mix...  i think you are better off with concrete  even without the cost factor...and this is just my opinion... gypcrete dries more than cures... vs concrete cure'n... the moisture i believe leaves concrete faster... i've seen alot of mold on gypcrete...  if you want the concrete can be a finished floor the gypcrete never can be..
    as for the price... it'd be a no brainer for me
    p
      Matt | Jun 19, 2006 02:09am | #8
      What was the mix for the lightweight concrete?  At what slump did your pour?  Did it have a plastizer in it?
      And.... where are the pics?  That sounds like a project for a rather expierenced concrete man - which I believe you are...
      1. ponytl | Jun 19, 2006 04:23am | #9
        experience is what you get by do'n...  I'm just dumb enough not to be scared of do'n anything...  usually inspired by less than steller work by "professionals" and by price...
        the mix was a pump mix so it had no slump... it was a 4000lb mix if i recall  might have been 3500lb...
        I was 20 ft up  but even if i'd been ground level the $1200 (if i remember right) for the pump was well worth it...  the pics are posted in the pic section might do a search use'n "ponytl" if you are interested...  yes it's hard work  but thats really what it is alot of labor RIGHT NOW  then it's chill for a few... then jump'n back on it with labor... you do want someone there that understands place'n and finishing concrete but if you have done your prep work and set your screed boards ur halfway to get'n a good job... what you have is 6hrs labor for 2-3 guys if you get everything ready... and with your infloor heat I think i'd want to pump it in... a small 3" pump should do... might cost you $500 for the pump and operator  but he's the one that should order the mix (you should tell him how much)... all depends on your skill & comfort level doing something like this...
        p
  4. vinniegoombatz | Jun 17, 2006 08:43pm | #6
    use the metal lathe   fasten it w a roofing gun    someone else sed it, gypcrete molds
  5. KeithSr | Apr 27, 2012 10:45am | #10
    Bad Idea
    I would not recommend putting 1-1/2" concrete on any wood subfloor.
    1. The structure may be rated to handle the weight, but it would put a lot of stress on the framing regardless.
    2. Any connectors you may need to use in the radiant tubing will deteriorate in concrete.
    I am currently busting up 1-1/2" - 4" of concrete from a house that did the same thing. What a disaster it is!
    1. IdahoDon | Apr 27, 2012 12:41pm | #11
      Pex is burried in concrete more often than not for radiant heat - as for connectors, there shouldn't be any in the concrete - that's easy.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
