concrete overlays
AdamGreisz | Posted in Construction Techniques on June 30, 2005 03:01am
I am considering installing concrete overlay (miracoate or increte (thincrete)) on top of 5/8″ cement board for portions of the second floor. This would be stained to match slab on grade @ first floor. This would be for public areas of second floor to match carpet height of bedrooms. Does anybody have any experience with this technique and or products. I am open to suggestions. Please help.
Adam Greisz<!—-><!—->
Owen Roberts Group<!—->
<!—-><!—-> <!—->10634 East Riverside Drive # 100 <!—-><!—-><!—->
<!—-> <!—->Bothell<!—->, <!—->WA <!—-> <!—->98011 <!—-><!—-><!—->
Office (425) 483-0234<!—->
Fax (425) 481-0299 <!—->
Cell (425) 273-6624<!—->
www.owenrobertsgroup.com <!—->
Edited 7/1/2005 6:54 pm ET by Adam Greisz
  1. rez | Jul 05, 2005 04:14pm | #1
    bump
    A person with no sense of humor about themselves is fullashid
    CloudHidden | Jul 05, 2005 05:43pm | #2
    We've used stamped polymer overlays (surecrete, I think), but it was installed by trained people and over a slab. The results have been great thus far. I'd think the underlayment and floor structure would make a big diff. The material has a great compression rating, usually in excess of 5000 psi, but if the floor structure is shaky, that won't matter a lot. Other than that, the installer should follow mfg recommendations.
      AdamGreisz | Jul 05, 2005 08:14pm | #3
      Thanks for the input. I have spoken to some local experts who believe that the products that I mentioned work great over wood frames. Instead of concrete board they recommend using felt paper, expanded metal lath, scratch coat and finish coat. The cost for this on the west coast is over $13 per foot. I was hoping to reduce the cost by doing some of the work myself. I feel more comfortable installing cement board instead of metal lath. I then might lay a base coat  and embed fiberglass mesh ( EIFS installation). Then install a finish coat. Still looking for recommendations or somebody to tell me I am crazy.Adam Greisz<!----><!---->
      Owen Roberts Group<!---->
      <!----><!----><!---->10634 East Riverside Drive # 100<!----><!----><!---->
      <!----><!---->Bothell<!---->, <!---->WA<!----> <!---->98011<!----><!----><!---->
      Office (425) 483-0234<!---->
      Fax (425) 481-0299<!---->
      Cell (425) 273-6624<!---->
      http://www.owenrobertsgroup.com<!---->
        BillHartmann | Jul 05, 2005 08:54pm | #4
        JLC had an article in the last year about someone that does do concrete thin overlays for the purpose of being able to stain or stamp them.They use them over both wood and floor bases.You can buy the article online at http://www.jlconline.com and look under Research.
          AdamGreisz | Jul 05, 2005 09:30pm | #5
          Thank you I will check it out.Adam Greisz<!----><!---->
