Concrete porch cap issues
yuer | Posted in Construction Techniques on July 27, 2014 12:50pm
My home is now 10 years old.   The  L-Shaped concrete floor for the front porch was poured over 3/4 inch tongue and groove plywood.   There is a storage area under the porch where the plywood is visable.   Recently I noticed one of the plywood boards has started to separate at the tongue and groove joint and is beginning to droup.   Since I’m pretty sure I can’t remove it, should I try to shore it up in some fashion?   Any ideas would be greatly appreciated.
Thanks,  Craig
  1. TLE | Jul 27, 2014 02:45pm | #1
    Is the concrete cap settling/cracking?
    If the concrete cap is failing, shore it up or replace it.
    If you are just talking about the plywood seperating and drooping, I would (and have in the past) cut it out.
    Run a sawzall (or multi master) cut around the edges (and you will ruin a number of blades).
    Pain in the butt work, but it is doable.
    Terry
  2. DanH | Jul 27, 2014 03:05pm | #2
    Generally plywood in such a situation is just forms that were not removed and it's not structural.  Unless it's an appearance issue, I'd just break/cut away the loose pieces.
Choosing a Paintbrush
  • The New Old Colonial
