concrete post base cure time
awschmidt | Posted in Construction Techniques on April 2, 2005 12:33pm
Hello all.  I’ve just poured a post base (rebared footing) in a basement floor.  The purpose of such is to support 1. jack pole, 2. 1st floor joists (cut out for new stairs),  3. stair well wall,  4. 2nd floor joists,  5.non-bearing wall.  The stair is a corner unit with basic 3′ square landing mid-rise and one 90 deg turn.  I had planned on a couple weeks prior to stair framing and subsequent concrete loading, but……….the customer has rearranged the schedule (they need a financial breather)  and would like the stairs done rather than other stuff.  Anybody have a guess as to how quickly I could load the concrete???  ps. basic quickrete mix, footing is a 24″ square base 16″ high tapering to a 16″ square at top. basement is a damp 50 deg temp.  thanks in advance
Kevin
    SamT | Apr 02, 2005 03:30pm | #1
    AMSchmidt,
    It depends on your load weight and the design strength of the concrete.
    This little sketch may help you visualize the concept.
    SamT
    1. awschmidt | Apr 02, 2005 03:45pm | #2
      Making the judgement call from your chart (crystal clear btw!), I think waiting at least 1 week prior to beginning would be the absolute minimum.  Thanks for the info.
      Kevin  (long time hammer swinger, inexperienced concrete man)  @ AW Schmidt
      1. dIrishInMe | Apr 02, 2005 05:15pm | #3
        1 week should a safe bet.
        Be aware though that the results obtained from bagged concrete mix is somewhat erratic due to poor quality control.  Heck though - guys here have reported getting bad concrete delivered by concrete companies too! Matt
        1. awschmidt | Apr 02, 2005 05:22pm | #4
          Thanks for the reassurance!
          Kevin
        SamT | Apr 02, 2005 07:53pm | #5
        Kevin,
        Well, the sketch wernt that clear. I couldn't draw the logarithmic curves that would have started steeper, then leveled off.
        Except in hi-critical and lo-critical conditions, a week is standard. In lo- critical  situations, like new framing, a day can be enough.
        I recently read of a job where the clients wanted a 1000 year foundation for a heavy religious monument. The GC poured a special slow setting mix very high in Pozollans for the first slab, on the order of 6'-10' thick. Then waited months to place a slip sheet of sand and pouring the second, identical slab on top of the first. They planned on waiting a year after the second pour to start building the monument.
        SamT
