concrete post foundations
sorethumbs | Posted in Construction Techniques on March 21, 2002 11:27am
Are sono-tube foundations acceptable in cold weather climates? I was recently told that condensation will form on the bottom of my cottage if I put it on a post foundation, even if its sits 24″ from the ground. Something about a warm cottage sitting even two feet above cold ground will cause moisture build-up with eventual mold then rotting. Did I receive good advice or is a post foundation fine for northern Wisconsin.
  1. Wolvie | Mar 21, 2002 11:29pm | #1
    I have to ask - why do you want to have your cottage up in the air?? You will get some condensation, no doubt about that - you can use water resistant or waterproof materials to counteract that , tho.
    Woe to the cook whose sauce has no sting
    - Chaucer
    1. sorethumbs | Mar 21, 2002 11:39pm | #2
      Quite a few reasons: I like the look of it, its a VERY economical type of foundation, the ground is not exactly level and the cottage will stick out over a small hill,  I'd like to promote air movement under the cottage to keep mositure down, I'd like access under it for future pipes and wires, etc.
  2. GabeMartel | Mar 22, 2002 03:45am | #3
    Davo,
    It should be fine, what gets damp will dry just as well. Been done a million times before, go for it.
    Gabe
  3. Davo304 | Apr 09, 2002 09:28am | #4
    Pete,
    I agree with you. BTW...the person who was asking for the advice was Dave-O , from Wisconsin.  I'm Davo, from the Pittsburgh, PA region.
    Davo
Outdoor Lighting
