concrete pour in basement
| Posted in Construction Techniques on October 1, 2003 05:53am
I’ve dug-out a trench ( 12″ D x 10″ from footing ) around the perimeter of my basement for an interior drain system.
The rest of my basement floor is sound but not exactly level, should I pour the concrete for my trenches first and then level the floor or pour it all at once. The floor would need from 1/2″ in some places to approx 2″ in other areas.
Thanks for any suggestions, Keith
    Flathead | Oct 01, 2003 06:48pm | #1
    Pour it all at once.
    WAHD
    1. AXE | Oct 01, 2003 08:50pm | #2
      Will a 1/2" of concrete even stay together.  I always thought you needed at least 1.5-2" to keep it from breaking apart.  I'm no expert though.
        Flathead | Oct 01, 2003 10:57pm | #3
        Personally I would try for 2" min.
        WAHDView Image
  2. csnow | Oct 02, 2003 07:43pm | #4
    Don't forget the vapor barrier.
  3. mike4244 | Oct 02, 2003 09:35pm | #5
    Pour the trenches first, that's if you need concrete there. I have seen gravel bottoms instead of concrete. I believe concrete sloped towards the pump would be better. Only pour the slab areas that are 1/12" or thicker. Use flash patch and a primer ( called milk) for the thinner areas. A masonry supply house can help you get the correct primer and flash patch.
    mike
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
