Concrete Sewer Pipe Repair
| Posted in General Discussion on May 28, 2000 10:31am
I’ve got a crack in the concrete sewer pipe leading out of my house. It is right where the storm drain connects at a Y on the underside of the pipe. This is old stuff (1924) and will be difficult to work with. Any recommendations? What about creating a form around it and pouring ready mix in to create a seal? Thanks in advance!
  1. Guest_ | May 28, 2000 08:57pm | #1
    Hi Mike,
    That old concrete pipe is delicate to repair. Just thinking about it will crack the pipe.
    You will have to carefully exposed the pipe around the entire broken section, use a patch and two adjustable strap clamps to hold it in place. Hand pack the sand under it and then cover the pipe with a little concrete, let set and then backfill.
    Gabe
    1. Guest_ | May 28, 2000 10:31pm | #3
      *Michael, there's a product called "Plumbers Dynamite" made by de Best Mfg in Gardena CA that is just what you are thinking of. Comes in 25# box. Might be available where you are, try your local plumbing supply. Joe H
  2. Michael_Wetter | May 28, 2000 10:31pm | #2
    I've got a crack in the concrete sewer pipe leading out of my house. It is right where the storm drain connects at a Y on the underside of the pipe. This is old stuff (1924) and will be difficult to work with. Any recommendations? What about creating a form around it and pouring ready mix in to create a seal? Thanks in advance!
