I’m getting ready to pour a slab for a hot tub. Do I need to compact the soil before I pour. The slab is 4″.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
How to Install Exterior Window TrimRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Nick
Up here in the interior of BC Canada we are concerned with frost for about 2-3 months out of the year. So in standard practice every slab that is poured would have a min of 6" of crush or 3/4 minus compacted under the slab. This crush prevents moisture from wicking its way up to the underside of the concrete inturn heaving when the weather turns cold. After looking at where you live you most likely do not have this frost problem but you should always tamp the soil before pouring a slab. Saves in the long run
Gordy
BC canada
*you should always compact any sub-surface under a slab, or else you could have settling cracks, concrete slab's aren't exactly supermodel light you know!good stuff
*Do I need to rent a compactor to so this or can it be done by hand? Thanks guys.
*yes
*In other words, for a small area use a hand-tamper, for a big area rent a power model. Or do it by hand and build up those delts and traps.
*Nic,I would suggest that you pour a 5" slab, 3,500 psi, reinforced with 3/8" rebar on 18" centers (placed just below the center of the slab. The base should not only be tamped, but also I would suggest wetting it - as in soaking it. If you use run-of-the-mill sand the soaking with water will help to settle the fines better. I usually spend an extra buck or two and use washed sand as it doesn't settle/compress as much as regular sand - more stabile in the long run is what I want to say.We're here in an area of Texas where "everyone" has cracked concrete, or so most of the local contractors say - well, not quite everyone. I've got about 1,100 sq. ft. of patio & pool decking that I poured in my backyard (to my specs.) about 9 years ago. I did it after 3 contractors told me that all concrete cracks here. That irritated the ... well, I wasn't happy with them. I'm an old union cement finisher. Hmmm, I'm still waiting for my concrete to crack. Good thing I didn't try to hold my breath.By the way, I'm assuming that your slab won't be more than 10'x10', if so then you need to allow for expansion joints - not control joints, but real expansion joints; otherwise, the concrete will crack on its own every 8' to 12' or so on average. I guess that's OK if you like cracks - I don't.I'd also suggest keeping the slab damp for a good 3 days, if possible. A visqueen cover and the addition of water on the slab and under the plastic will do the trick. I'd check on the water every 1/2 day or so depending on the weather and add water as needed. If the plastic rests on the slab you may get some irregular surface coloration on the slab. If this is a problem and the slab isn't too large then you could make a "tent" of the plastic to keep it off the concrete.Good luck,Cliff.
*Yea Cliff. Concrete and cracking do not necessarily go hand in hand. Too many seem to expect it which gives permission for poor workmanship. Drive on. Randy
