concrete slab – 4.5 or 5 sack?
txkevin | Posted in General Discussion on January 11, 2007 08:33am
Is there a real advantage to using 5 sack concrete when pouring an new residential slab or is 4.5 sack sufficient?  The engineered plans spec 3000 psi min.  Contractors state 4.5 sack is the standard.  Is 5 sack overkill or a reasonable quality spec worth the extra cost?
Thanks in advance for your opinions.
    McDesign | Jan 11, 2007 08:45pm | #1
    Personally, I only do slabs (monolithic, usually here in GA) at "6-sack" equivalent.  Like 3500#, with the fiber also.  Just feel better about it, since everything else I build might be sitting on it.  Foundations have more section modulus, so I can go with 2500-3000 on them.
    1. txkevin | Jan 11, 2007 09:08pm | #2
      Of 3 bids, all spec in 4.5 sac as standard but sometimes up it to 5 sac.  Seems to be the difference of 3,000psi and 3,500 psi.  Ground here is stable (weathered limestone) so I am wondering if I should stay with the standard or up it to 5 sac to be sure.
    2. davidmeiland | Jan 11, 2007 09:40pm | #3
      We always pour 6-sack slabs. Easier to work with and a nicer finish.
      Gene_Davis | Jan 13, 2007 07:38am | #6
      OMIGOD!
      Section Modulus!
      More sacks or less sacks!
      Did I wander into a chat room about E.D.?
      Gene, former B.S.C.E., after two Glenlivets and more cabernet than he can recall . . .
        McDesign | Jan 13, 2007 05:18pm | #7
        We have to spell things creatively to get around the Sensors (see how I didn't flag the "censor" tag?)
        Whoops!
        Forrest - more sacks makes you stronger
  2. dovetail97128 | Jan 13, 2007 06:50am | #4
    For me it would all depend on the upcharge. If it isn't much I would go for the 5 sack. But 4.5 works so all you are paying for is your own peace of mind.
    1. brownbagg | Jan 13, 2007 07:22am | #5
      we use 6 sack so we can pour a little wetter and still get good break. a 4.5 sack is really a weak 3000, so anything over 4 inch slump I be scared. withs a 6 sack, a 6 inch slump still breaks good.
      Edited 1/13/2007 9:28 am by brownbagg
