Concrete Slab Design
Frankie | Posted in Construction Techniques on April 30, 2009 10:38am
Okay, you’ve dug a basement 15′ deep. Ground is dry as bone. Buildings to the left and to the right. All roof water feeds to internal drains. Back yard is less than 750sqft.
Slab sits on foundation wall footings and grade beams which span the width of the basement.
Everything has properly installed rebar as spec’d by an engineer.
Q. Time to pour the slab. Can the slab be poured directly on the compacted soil ( with a 6ml vapor barrier) or is there a reason that I MUST include 6″ of compacted gravel? I don’t see what the gravel serves in this situation. I get it’s purpose in a country house.
I ask because there is a ceiling/ floor height issue and I cannot dig deeper.
Frankie
Flay your Suffolk bought-this-morning sole with organic hand-cracked pepper and blasted salt. Thrill each side for four minutes at torchmark haut. Interrogate a lemon. Embarrass any tough roots from the samphire. Then bamboozle till it’s al dente with that certain je ne sais quoi.
Arabella Weir as Minty Marchmont – Posh Nosh
  1. john7g | Apr 30, 2009 11:09pm | #1
    I think the gravel serves as a capillary break between the soil and your CC.  The plastic helps but can be compromised during the pour.
    I've got very little experience in doing CC other than watching others do it but I wouldn't skip the gravel. Do it wrong now and you won't get a 2nd chance to do it right and forever regret it.
  2. brownbagg | May 01, 2009 01:25am | #2
    we do it to 99.9 % of our slabs that way
    1. Frankie | May 01, 2009 05:08pm | #4
      Thank you all for your help. Directly on compacted soil it is.Frankie
      Embarrass any tough roots from the samphire. Then bamboozle till it's al dente with that certain je ne sais quoi.
      Arabella Weir as Minty Marchmont - Posh Nosh
      1. Snort | May 02, 2009 01:19am | #5
        We have to have gravel, unless, something else is approved by a soils engineer...http://www.tvwsolar.com
  3. FNbenthayer | May 01, 2009 02:12am | #3
    Most of the "dig downs" I have seen in bkn were poured on without gravel, just the undisturbed/compacted sand.
    There are some vestigial underground streams that can rise in spring depending where you are... someone at DEP might be able to help.
    Jim
    The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.
    - Fyodor Dostoyevski
Mortar for Old Masonry
