what is common base or footing to set conc stepunit on , step co say crushed stone is fine, installed on backfill would rather excav and pour conc pad , worried about settling problems. any thoughts ? thanx
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
You may get better answers by adding more information:
Are you talking about a precast concrete step or are you planning to cast it in place yourself?
How high?
How big and area?
Everything else you can say about your situation...
Good luck!
