I am lookinfg for a sealant for the transition between a concrete slab (ceiling where the old well pump was) & the brick on this house. what is the product use in commercial applications i have seen that produces a wide flexible bead? the product shown in the picture is duct seal that i had, but it isnt sealing, i still get water in the basement. thanks!
Greetings jim,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
-Thoreau's Walden
I think what you want is Sikaflex. (sic). That and you might want to look at your drainage.
A problem with concrete pads/sidewalks/etc next to a structure is that the backfill takes forever to compact. Regularly I have seen concrete tilting toward the building. You probably have two choices: break it out and redo the soil drainage near the house or have the pad mudjacked.
JohnD1, thanks for that bit of advice on the pad sloping, i checked it & it slopes away from the building, i will check into the sic...
Moopy, i was googling Sikaflex & there are several kinds, any certain one you recommend? remember, i think i am looking for a very wide bead (i think), wider than a typical caulk gun tip provides.
jim,
I think if you read the specs and installation on the Sika products there are instructions for dealing with wide cracks. Can't remember your exact situation and th epic but if it is a small slab you may be able to use a big bar as a lever and slide it closer to the foundation ."Poor is not the person who has too little, but the person who craves more."...Seneca
there isnt a wide crack at all, water just migrates thru, i thought a wide bead like i see in commercial applications in concrete expansion joints, between precast concrete walls, etc would be best, rather than just a 3/8 or so that you get with a normal caulking gun. maybe i just need to run a few beads on top of each other & tool it into a wide bead. a tradesman buddy of mine thought that he saw this type of sealant being used from a pail, not a caulking gun, maybe its available either way. i just thought right now that maybe i should check with Graingers... this area also has a lot of sun (east side)
Sika has a product that is very flowable, it comes out of the cartridge almost like cream, it will go deep into a crack and seal it up . Self leveling so you don't have to tool it at all."Poor is not the person who has too little, but the person who craves more."...Seneca
so tell him about Vulcum and or Sikaflex...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
