condensating pole barn
GregWerner | Posted in Construction Techniques on May 3, 2004 12:54pm
Had a call from a guy that has a pole barn( that somebody else built) that seems to have an awful lot of condensation on the inside of the metal roof. Everything is finished and insulated( cieling is insulated, attic is not) Anyway the condensation is making its way to the drywall and causing stains. He would like me to give the attic more ventilation to fix the problem.
Will this  fix the problem? The gable vents are really small and he has no soffit/ ridge vents. All help will be appreciated. Thanks.
Greg
Werner Building &  Remodeling
Huntingdon PA
  1. maverick | May 03, 2004 04:14am | #1
    Simple answer, YES! You can never have too much ventilation.
    With no soffit and a metal roof your gonna want to vent thru the gable ends. Maybe with bigger vents and an electric gable vent fan.
      GregWerner | May 05, 2004 02:55am | #2
      Thanks for the help. I was thinking ventilation but wanted a 2nd opinion before I start cutting holes in his gables.Greg
      Huntingdon PA
Mortar for Old Masonry
