condensation problems
ashcon | Posted in Energy, Heating & Insulation on November 3, 2004 11:31am
I was aproached with a question from a customer as follows:
In the morning as the weather is gettng colder they have avery bad
condensation problem on their windows , like water drippng bad
what is causing this problem?
Being a better capenter than a HVAC expert I’m lookig for help!
  1. DanH | Nov 04, 2004 12:32am | #1
    Moisture.
  2. sungod | Nov 04, 2004 03:54am | #2
    Common causes are moisture producing items such as unvented dryers, using open gas stove flame to cook or heat the house and heated aquariums.
    1. DanH | Nov 04, 2004 04:40am | #3
      In a new home, the framing and drywall will contain a lot of moisture, plus any exposed concrete will contribute a lot.
  3. HammerHarry | Nov 04, 2004 04:45am | #4
    There is so much moisture in the air inside that it condenses when it hits the cold window.
    Now the questions:  how old is the house; how many people live in it; how is it heated and ventilated?
  4. mauri | Nov 05, 2004 08:12pm | #5
    Are the windows single pane ?
    rjw | Nov 05, 2004 09:57pm | #6
    Back drafting of flue gases can be one cause - don't overlook that
    The other questions will all aid in a diagnosis
    The key to forgiving others is to quit focusing on what they did to you, and start focusing on what God did for you. Max Lucado
    Sojourners: Christians for Justice and Peace
    jocobe | Nov 05, 2004 11:45pm | #7
    What brand windows?  What year were they installed?  Insulated glass?
A New Approach to Foundations
