Construction Master IV to calculate m…
| Posted in General Discussion on January 12, 1999 11:50am
Suppose you’re working with crown moulding that does not make the typical 52/38 degree angles with the wall and ceiling. I’ve found a way to “trick” my Construction Master IV into giving me the correct mitre and bevel angles. The only information you need is the crown moulding angle, which is very easy to find. Just cut a small piece and trace it onto the corner of a piece of plywood or whatever, and measure the angle with your angle square or with a compass.
b This method is for rooms that have square (90 degree) corners only.
In the example below, the calculator is used to find the mitre and bevel angles for 52 degree crown moulding. When you hit the pitch button in the last step, you should get 31.62 for the mitre and 33.86 for the bevel. For any other crown angle, simply replace the 52 with the new angle and follow the same steps.
b The Mitre Angle
1) conv x
2) 52 pitch
3) 1 = diag
4) run = rise
5) 1 = run
6) pitch
b The Bevel
1) conv x
2) 52 pitch
4) run
5) conv (squareroot symbol)
6) + 1 = (squareroot symbol)
7) conv (divided by symbol)
8) x rise = rise
9) 1 = run
10) pitch
It is possible to get the calculator to do this for ANY wall angle in combination with ANY crown mould angle but there would be quite a few more steps involved. I may post these later if there is any interest at this site.
I don’t believe that earlier models of the calculator will yield the correct results.
  1. Guest_ | Dec 30, 1998 01:12am | #1
    I am repeating the steps to calculate the bevel. Apparently while editing I somehow deleted step 3.
    Here is the correct set of steps to calculate the bevel
    b THE BEVEL
    1) conv x
    2) 52 pitch
    3) 1 = diag
    4) run
    8) x rise = rise
    9) 1 = run
    10) pitch
