Construction Questions
AdventureBob | Posted in General Discussion on December 16, 2013 11:44am
Im a newb and have never watched a house being built.  I have some quality questions about the framing work.
How much gap in the sheathing is acceptable?  Is there a code refrence on how big a gap can be in the sheathing?
How much split wood is acceptable in the framing?  I realize this isnt finished furniture but would like to know what folks hold as a rule of thumb on split lumber.
Thanks in advance…
  1. Piffin | Dec 17, 2013 06:18am | #1
    You need about 1/8" gaps
    You need about 1/8" gaps betwen sheathing.
    No splits are acceptable, esp n studs, but you do get some checking in rafters and joists occasionally. This comes from wood drying and shrinking.
  2. AdventureBob | Dec 17, 2013 07:51pm | #2
    Code Source
    Is the gappage and splits referencable to code or generally acceptable practices?
      coonass | Dec 17, 2013 09:48pm | #3
      Bob,
      Unless the sheathing is spaced it will swell and show a bump or dip in the shingles. Says to gap 1/8" right on the panel.
      Some splits in framing material is fine others are not but your house won't fall down because of a few splits. Talk to your GC about your concerns .
      KK
  3. E Beard | Dec 17, 2013 09:58pm | #4
    Spacing Plywood
    As a carpentry apprentice, as well as instructor. Sheating should have a 1/8" gap minimum along the long dimenson, and double that at butt joints 1/4" this is to allow for expansion due to changes in humdity.
    H clips used on roof sheating not only increases mid span strenght, but provides the gap I metioned.
    Good luck,
    Eddie
