Are construction staples used to fasten stucco paper And wire within code?
![](https://images.finehomebuilding.com/app/uploads/2024/07/09110145/01232520-hybrid-powered-router-thumb-16x9.jpeg)
Metabo HPT's dual-powered plunge router offers the option to plug in an otherwise-battery-operated tool for production work.
yes...
at least 1" wide ones
WOW!!! What a Ride!
Thankyou!!!!
While we are at it, would you know where I can find international building codes on line?
Each jurisdiction can adopt a different code, as well as have supplements.If you are in the US try your states web site.
bobl Volo, non valeo
Baloney detecter WFR
"But when you're a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn't matter." SHG
since you haven't filled the very basic of information in yur profile...
everybody seems to work under a different set of rules so some answer from here are libale to right on the money and others can very easily be out in left field....
look to yur state and county for your building code needs...
