Continuous wet use for shop vac?
alecs | Posted in General Discussion on December 20, 2005 06:41am
Hi,
I was helping to remove about 1/2″ of standing rainwater from a basement in a house that is under construction. The basement was about 1500 sf. There is no floor drain or sump pit.
What we did was to set up a shop vac outside, run the hose through the window, through the handle of a weighted down 5-gal pail, and then set the nozzle of the vac on two little shims so that it set about 1/8″ above the floor. Then, we put two 2x4s in the shape of a vee, with the point of the vee right at the vac nozzle. Using snow shovels, we encouraged the water into the vee. It worked great, especially once we set up the 2×4 vee to direct the water towards the nozzle.
The only problem was that we had to keep stopping every few minutes to turn off the vac and open the drain plug. I was hoping for some suggestions on how to make the shop vac act more like a sump pump and operate continuously without having to stop and drain. Merely running the vac with the drain open did not work, the vac just wants to suck air in through the drain hole. A sump pump was not really an option because the water was very shallow.
Thanks for any ideas!
Alec
  1. MSA1 | Dec 20, 2005 06:50am | #1
    My shop vac has a drain on the bottom. It wouldnt exactly operate like a sump, but as long as the water in the tank stayed above the drain hole (to maintain vacuum) you could keep the machine running without having to keep draining the tank.
      alecs | Dec 20, 2005 06:57am | #2
      We tried that, but since the vacuum was sucking water off the floor about 4' below the drain plug, the path of least resistance was to suck air in through the drain plug rather than water up the 4' of hose.
  2. DanH | Dec 20, 2005 07:03am | #3
    Break down and buy a real pump. You can buy a cheapie sump pump, or something like a small Wayne centrifugal pump. Or, you can maybe find a small vane pump sans motor and power it with a drill (drill press works best).
    happy?
      alecs | Dec 20, 2005 07:06am | #4
      Can you recommend a type of pump that will suck 1/2" of water off a floor and pump it out the window? I thought that most pumps for that application would need to have a sump pit or deeper water to work with.
        bobl | Dec 20, 2005 07:22am | #5
        wonder if this would workput the picture in a folder namedFloyd's Pond Vacum_filesthen open with browsercame accross this for my pond
        bobl          Volo, non valeo
        Baloney detecter
      2. DanH | Dec 20, 2005 07:46am | #6
        Some pumps come with a hose end (I think they call it a "frog") that will pick up down to about 1/2", or you can generally devise something. Worst case just hook the pump up to the vac hose.
        happy?
  3. alwaysoverbudget | Dec 20, 2005 08:15am | #7
    get you a cheap sump pump and attach a hose to it. sit it inside your vac and either drill a hole or use your drain hole to exit hose.seal around the hose pretty well and start vacuming,you'll never stop to drain.have fun been there done that. larry
  4. ELoewen | Dec 20, 2005 08:44am | #8
    how about a flap valve on the botom of the vacum that gets sucked closed by the vacum when it is turned on and when the vacum is turnd off the preasure of the water forces it open
    put a timer on the vacum to turn it on and off at regular intervals
    saw some roofers useing a trailer mounted vacum to remove the gravel from a roof this way' every time the vacum would stop the gravel would drop onto a truck below the cyclone
    1. DanH | Dec 20, 2005 04:01pm | #9
      Around here I've seen them use an old snowblower to pick up the gravel. (Wear ear protection!)
      happy?
    BillHartmann | Dec 20, 2005 05:02pm | #10
    There are all kinds of utility pumps that will go down to 1/8" or less.
    Here is one.
    http://www.lgpc.com/Product/ItemDetail.aspx?ProductID=404
    BossHog | Dec 20, 2005 06:29pm | #11
    I wonder if one of those garbage can lids for dust collection systems would work.
    Then you could let both the garbage can AND the shop vac fill up before you stopped to empty them.
    Not continuous, but better 'n nothing...
    Love your neighbor. but don't get caught.
  7. jefflitzy | Dec 21, 2005 01:52am | #12
    You can get a shop vac with a built in pump that connects to a garden hose
    http://www.shopvac.com/web/products/list.asp?hdnSource=index&Browse=pump
