Contractor drilled faucet hole 1/4 off center in new granite counter top…now what?
whattado | Posted in General Discussion on December 13, 2012 11:41am
We are in the middle of getting new granite counter tops installed and the contractor drilled the faucet hole off center at least 1/4 of an inch. The hole he drilled is 1 1/4″. Is the any way to correct this problem without getting new granite? HELP!!!!!
  1. florida | Dec 13, 2012 05:47pm | #1
    I'd say the contractor owes you a new top. if you want to be a nice person maybe the contractor can find a larger escutcheon for the base of the faucet that wil cover the mistake.
  2. calvin | Dec 13, 2012 08:35pm | #2
    Now,
    is that a very important qtr inch?
    If so, you should ((he or granite guy and he pays)) be able to grind a bit and move it over an 1/8th w/o showing hole outside the base of the spout (which I presume is a one hole install) on/off and sprayer in one.
    Could you live with an 1/8th off?
  3. DanH | Dec 13, 2012 09:26pm | #3
    If the hole is going to show at all after re-drilling it correctly, you can probably get the countertop guy to patch the space pretty well.  Presumably the amount showing will be just a sliver, so the patch wouldn't be particularly visible, if done well.
    But all this should be on the contractor's dime.  And he still owes you one.
  4. Waters | Dec 14, 2012 01:26pm | #4
    If it doesn't show under the faucet's baseplate then it doesn't matter.
    If it doesn't allow you to place the faucet assembly correctly, then possibly the hole can be 'adjusted' or enlarged so that you can, provided the baseplate will still cover.
    The granite folks can also fix that hole invisibly the same way they make seams, with color-matched epoxy, and a scrap.  Then redrill the hole.  Only you might see this imperfection, because you know it's there.
    If your world is actually going to end, because of this human error, then I suppose you will have to go toe-to-toe in negotiation with your contractor to find a mutually favorable agreement.
    Best of luck.
