control Fein vac on/off at end of hose??
Fonzie | Posted in General Discussion on January 8, 2006 07:07am
I was wondering if there is a simple/safe way to use the auto-on feature of the Fein and run a wire up to the business end with a button to turn it on and off (it could just unplug from the auto-control outlet for use with a tool).
  1. JulianTracy | Jan 08, 2006 07:53am | #1
    That's a heck of an idea. Something as simple as a 120volt led or bulb mounted to a nicely designed switch would probably do it.
    Maybe even better would be to get one of the remote controls designed for dust collectors. They run about $50-60 - check PennState's web site.
    Also, some folks have had good luck using the remote controls designed for xmas lights for smaller dust collector units, check one of the Ace or Aco's maybe see what the specs are.
    JT
      Fonzie | Jan 08, 2006 04:30pm | #4
      "Maybe even better would be to get one of the remote controls designed for dust collectors." (Julian Tracy)Ah, you just gave me another idea. My wife has a remote control outlet for the Christmas Tree lights I could plug in the outlet of the Fein with a night light. (now, where's that remote?)
      Fonzie | Jan 10, 2006 07:56am | #5
      Ah, the convenience! The remote worked great! A "night light" won't trigger the Fein auto-on feature however - I used a socket with a 60 wt light bulb. The remote control outlet was about 10$ from Wal Mart - it plugs in the Fein special outlet. The light bulb plugs in the remote outlet. The remote is a key-chain size. This will be great for several situations; such as when we locate the vacuum outside the room when sanding.
        JeffBuck | Jan 13, 2006 05:53am | #6
        ua got me there ... the hose IS longer!
        I was wondering if/what ya rigged up.
        was the remote a first run winner?
        I was thinking ... the idea of a wire and switch "should" be made to work ...
        I still just walk back though!
        Jeff    Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
          Fonzie | Jan 13, 2006 07:09am | #7
          Hey Jeff,I know I'm going to catch it for this - haven't had time to make this look pretty yet. Notice the nice little keychain remote! I'm telling you there are situations where you won't mind the convenience of this.You don't have to be looking at the vac for this little 10$ remote outlet to work.
            JeffBuck | Jan 13, 2006 08:59am | #8
            Holy Cluster-F#$% Batman!
            That pic is fantastic ...
                 Pittsburgh Pa
            JeffBuck | Jan 13, 2006 09:00am | #9
            btw ... is the light so U can find yer keys in the dark?
                 Pittsburgh Pa
            Fonzie | Jan 13, 2006 04:24pm | #10
            Ah, the spark of invention lights the fires of convenience!
    JeffBuck | Jan 08, 2006 07:58am | #2
    just for general cleaning?
    is it really that hard to walk 10 ft back to the vac?
        Buck Construction
         Pittsburgh Pa
      Fonzie | Jan 08, 2006 04:27pm | #3
      "is it really that hard to walk 10 ft back to the vac?" (JeffBuck)Yes, you got me on that one (but I think the Fein hose is longer). I think the source of this is my basic dislike for cleaning. (subconscious maybe getting up). Thanks for the whine alert.
