Convert cental air conditioning unit to air conditioning and heat pump
lomonaco1962 | Posted in Energy, Heating & Insulation on December 15, 2013 05:05am
 Is it possible to convert central airconditioning unit to central heat pump and air conditioning and if yes how do you do it? Thank you
  1. DanH | Dec 15, 2013 06:26pm | #1
    You might be able to reuse some of the ductwork.
  2. gfretwell | Dec 15, 2013 09:39pm | #2
    It is basically a one for one swap. The devil is in the details. What are you using for heat now? Is your duct work set up for heating? What will you use when the heat pump is not enough? Answer that and you have an idea of what it really means.
    Mike_Mahan | Dec 16, 2013 10:37am | #3
    "if yes how do you do it?"
    "if yes how do you do it?" You don't do it. You hire an HVAC contractor.
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
