Cope/Miter Azek Crown
FR | Posted in Construction Techniques on September 12, 2010 10:40am
Guys,
First time I’m working with Azek crown molding.   Any suggestions on whether to cope or to miter/glue the corners?
Thanks.
FR
  1. calvin | Sep 12, 2010 11:12am | #1
    Users choice I suppose..........
    and I've worked with azek and it's competitors b/4, but never with the crown mold.  Since a joint in azek is almost "welded" together using their glue, I think I'd go that route.
    1. Hudson Valley Carpenter | Sep 12, 2010 11:24am | #2
      So would you use MIG or TIG? Miter or cope?
      " I think I'd go that route."
      Welding is one way to cope with a joint problem, true.  I might-er done 'er the other way, myself.
  2. JTC1 | Sep 12, 2010 12:22pm | #3
    Well
    take this for what it's worth.
    I miter simply because a miter joint provides greater surface area for gluing.
    I use the fancy Azek cement rather than plumbing variety PVC cement because it seems to allow more open time. Azek cement is ~$12 a can vs $ 5. for Oatey.
    I have run a rudimentary test for bond strength between the Azek cement vs Oatey PVC cement -- seem equal, so it becomes your choice.
    Jim
  3. Whitewood_Millwork | Mar 22, 2021 12:58pm | #4
    I agree with Jim. You could use a thicker adhesive which will also act as a filler, but a PVC cement is good.
