Copper bay window
Slater | Posted in Photo Gallery on March 6, 2004 09:27am
I redid this window this week.  I stripped the old roof and window apron down to framing.  I shimmed, planed and installed 1/2″ A/C plywood over this new straight structure.  I then fabricated,  installed and patinaed all of the parts.  Three long days of work, from set up to pictures.
  1. seeyou | Mar 06, 2004 09:53pm | #1
    Nice work, Terry. I've got a similar project coming up. I'm redoing an entry that someone started and didn't know how to finish. Lots of galvanized face nails on it to make the copper lay flat.
  2. Lateapex911 | Mar 06, 2004 10:38pm | #2
    Nice!  MUCH better! Those old shakes were just the wrong scale for that bay, IMHO!
    How did you handle the junction between the brik and the copper? Were you able to save the existing? Did you cut a kerf in the mortar to  let new flashing into?
    Looks like it's always been there....that best you can hope for!
    Jake Gulick
    [email protected]
    CarriageHouse Design
    Black Rock, CT
    1. joewood | Mar 06, 2004 11:03pm | #3
      Say Terry, could you share with us your patina method ?
      I've been looking around and trying different methods, but I'm not happy with the results.
      1. calvin | Mar 07, 2004 12:52am | #4
        He must have done it on the ground.  No one can pee that high up.Remodeling Contractor just outside the Glass City.
        Quittin' Time
      2. Slater | Mar 07, 2004 07:49am | #7
        Joe
        The patina I used was old fashioned "liver of sulphur".  That's just a slang term for sulphurated potash.  It comes in a cake form which you crumble up and add as much as needed to hot water, where it readily dissolves.  You apply it to warm copper which I preheat with a weed burner.  It's very simple, fast and easy to control.   Application of the "liver of sulphur" can be done with a spray bottle a sponge to dab it on or with a brush as I did here.  I've even heard of applying it indoors in an enclosed environment using a humidifier.  This gives a very even finish.   Adjustment of the color is by the concentration of the mixture and by the amount of heat used as the mixture is applied.
        This mixture is easier than most because unlike most it doesn't require a perfectly clean surface to begin the process.
        Good luck
        Terry
        P.S.
        You'll find sulphurated potash at any chemical supply, at a statuary casting supplier, or search here for patinas.
    2. Slater | Mar 07, 2004 07:33am | #6
      Jake
      The existing counterflashing was poorly done (crooked and to shallow a reglet).  I cut in a new reglet 2"s above the old one and counterflashed there.
  3. StanFoster | Mar 07, 2004 05:33am | #5
    That is real classy looking...way to go
  4. Slater | Mar 07, 2004 07:53am | #8
    Thank you all for your kind words.
    It's a real pleasure for me to share what I do.  I really enjoy discussing techniques with you all.
    Thanks again,
    Terry Smiley
