Grant ,
This portico is 4′ 1″ out from the house .
What might that cost if it was within 1 hours drive from you to fabricate and install ?
Is 2 grand in the ball park for a 16 oz . locked seam soldered roof ? Flat wall behind .
Thanks for the input .
Flashed to brick, $2K would be pretty dead on. About $400 less if just turned up the wall under siding.
I 'd lay that out so there'd be no soldering except on the wall flange.
You doing OK? You've been pretty quite of late.
http://www.quittintime.com/ View Image
There's enough other noise makers lately so I could lay back a bit !!
The archy I think wants locked and soldered joints .
I'm doing fine thanks , just not up to posting quite as much lately .
Ever work up a price per sq . on your copper shingles ??
Best , Walter
