corded drills
DonCanDo | Posted in Tools for Home Building on November 30, 2006 04:26am
I rarely use corded drills anymore, but I had to bore holes for several locksets today.  I pulled out my Dewalt corded drill and the whole time I’m using it, I’m thinking that it doesn’t really seem all that powerful.
For the sake of comparison, I drilled a bunch of holes (using an 1 1/4 spade bit)with a Ryobi 4.5 amp drill and then again with the Dewalt 6.0 amp drill.  I really forced the bit to purposely put a high load on each drill.  Much to my surprise, the Ryobi (about $30.00) significantly outperformed the Dewalt (about $70.00).
Obviously, amps is not the complete story.  There was a discussion recently about reciprocating saws and amp ratings.  Most agreed that amps is not always a true indicator of power.  And there you go.
Still, I’m not sure that the Ryobi is a “better” drill.  Both drills were starting to smell like something was burning, but the Ryobi smoke was a little stronger.  It may not last, but for the price, it’s a nice backup.
When the Ryobi finally goes up in smoke, I’m going to replace it with a better drill, but probably not a Dewalt.  Even if the new Dewalts produce more power, I’m just not crazy about its ergonomics.  What drills do you folks like?
-Don
  1. CAGIV | Nov 30, 2006 04:30am | #1
    Milwaukee
    Team Logo
    IMERC | Nov 30, 2006 04:33am | #2
    Milwaukee magnums
    WOW!!! What a Ride!
    IMERC | Nov 30, 2006 04:41am | #3
    sounds like the DW has intrenal problems...
    WOW!!! What a Ride!
  4. mike585 | Nov 30, 2006 06:05am | #4
    Don
    Picked up this one a couple of months ago. I don't know if the deal is still available. Plenty of power.
    http://www.tylertool.com/mi021vsrmadr.html
    Mike (from bikefest)
  5. FastEddie | Nov 30, 2006 06:10am | #5
    I have a Milwaukee 3/8" electric that is very nice and very powerful.  It even came with a sticker on the housing warning about torque.
  6. alwaysoverbudget | Nov 30, 2006 07:30am | #6
    buy a 1/2 millwaukee. be sure your health insurance is paid up.if the bit hangs up,it's you or the drill.my drill always wins,haven't broke a wrist yet,but...... larry
  7. rasconc | Nov 30, 2006 08:44am | #7
    What is the chuck size and rpm rating of the two drills?  Like said amps ain't everything.
  8. IdahoDon | Nov 30, 2006 08:58am | #8
    Ahh....the pleasant smell of Ryobi smoke.  *chuckle*
    When it comes to drilling speed, what seems to be most important is speed.
    I have a 5 amp 3,000 rpm Makita specifically for sinking deck screws.  This is too fast for many purposes and too slow for fast wood drilling, but it's about perfect for putting in screws.  A 4" Torx-head screw will be smoking at the tip when it's driven into doug fir, and if backed out and sunk again the screw will be so hot it easily strips out even if started in a new hole.  It's really too fast for good screw control (pardon the expression.
    The Dewalt 2,500  rpm, 6 amp drill is the general purpose drill for metal drilling, large diameter spade bits, paint mixing and larger deck screws.  The speed and torque on the low end is nearly perfect for good control when sinking most screws.  Like most Dewalt tools it's tough, but feels a little clunky.  Having been around 4 different Dewalts just like it, they have all lasted much longer than they should have with the roughest of use.
    Then there is nice and light 3 amp Makita turning 2,200 rpm specifically for drilling pocket screws, shelf pins, counter sinks and other light duty repeditive drilling.   I love the way it fits the hand and how easy it is to use.
    These three drills are similar, but each is only ideal for a small range of uses.
    A 4,000 rpm drill would speed up repetitive wood drilling with larger twist bits.
    1. DonCanDo | Nov 30, 2006 03:20pm | #11
      Thanks for the input.  I was looking at the Milwaukee since I already have some of their tools and I like them.  It's good to hear that their drills are well-liked too.
      As for RPM, the Ryobi is rated at 0-1400 and the Dewalt at 0-2500.  That may explain why the Ryobi did better with a spade bit.  I'm assuming it's geared lower and a spade bit requires torque rather than speed.
      -Don
  9. User avater
    Sphere | Nov 30, 2006 02:51pm | #9
    Milwaukee for the serious stuff .
    I have irriatable Vowel syndrome.
    1. junkhound | Nov 30, 2006 03:03pm | #10
      old souix drill motors
  10. LeeLamb | Nov 30, 2006 04:19pm | #12
    Milwaukee, Milwaukee, Metabo and Thor (over 60 years old and still going strong  ;-)  )
      IMERC | Nov 30, 2006 04:22pm | #13
      I have the D handle Thor in 5/8...
      IIRC thety were made by Grumman..
      1. LeeLamb | Dec 02, 2006 04:32am | #19
        Thanks!  It was the only electric drill my dad ever owned. He was a roofer-tinner and gave it a pretty good workout, as have I. I really like that tough old piece of aluminum.
  11. Mooney | Nov 30, 2006 07:32pm | #14
    As has been said , it depends what the job is at hand .
    Different drills have different uses .
    However , its hard ro beat a dual speeded drill in half inch chuck size with a varible trigger for powerful jobs. Thats what I would have chose to do the job you were doing . Ive got two in that size that also are hammer drills which again is another nice feature .
    To further choose the right drill for that job alone , I would have picked up the Milwakee that has a lower setting of 300 rpms. Power plus setting that doesnt mind hitting Oak if you dont . I prefer a slow and powerful drill for that application. Thats far out of the cordless feild of power except in 24 volt. Even then I wonder if a 24 volt would stand beside it . I dont own a 24 volt.
    Point being is that you wouldnt drive screws with a 24 volt and probably wouldnt mix SR mud with one either . Thats why we have so many different types of drills. For pre drillling hinge screws its hard to complete with a 1/4 inch corded drill, so there ya go. I have 5 Makita 1/4 inch drills , and several 3/8s to 1/2 inch in the same brand of corded drills . Makita doesnt seem to ever die in my shop. They are basically simple drills that I have that have provided heavy service  for a number of years. Drum roll please ,,................... I have a Makita 1/2 inch drill that saw daily use for 15 years that stayed connected to a mud bit . It is  30 years old and will still whip up a 4 gallon box of joint compound in a five gallon bucket. The cord frayed years ago and had been replaced three times . I challenge any cordless drill to that record. I have another drill that is its match exactly that is several years newer but is still considered an old drill at roughly 15 years old. Its used for multipurpose wiring jobs and boring locksets and the like . This past year it was taken out of the truck tool box for a much newer Milwaukee that has all the bells and whistles I talked about above . The Makita never wore out , it just got out dated. What I really like about the newer drill other than impact is the dual range with varible speed which in a pinch can mix paint at a varible slow speed in 5 gallon buckets with out sloshing if its asked to. It will drive leg bolts seurely till the cows come home if I am with out a impact wrench.
    Tim
    1. grandchat27 | Nov 30, 2006 08:56pm | #15
      Just for the record (and b/c I haven't heard many people mention this brand), I really like my Ridgid 1/2 hammer drill (R5010 - see link).  I have used it many times under pretty tough conditions and it has held up wonderfully, and I have never seen or could not smell any smoke no matter how hard I pushed the drill.
      In particular, the pulse mode is very handy, as is the "cruise control" feature when drilling in concrete of any significant depth.
      http://www.ridgid.com/MenuDriver.asp?ParentID=R5010-Hammer-Drill
  12. unTreatedwood | Nov 30, 2006 10:58pm | #16
    all Milwaukee, all the time.  24 hrs/day
    "The nearest thing to eternal life we will ever see on this earth is a governmental program"  -Ronald Reagan
  13. rnsykes | Nov 30, 2006 11:01pm | #17
    I have the 6 amp Hitachi.  very well made tool.
  14. rustbucket | Dec 02, 2006 02:19am | #18
    Second...Milwaukee...Hole Shooter
    rustbucket
  15. jc21 | Dec 03, 2006 10:04am | #20
    Another vote for Milwaukee but I'll qualify that by saying stick to the older design models. My 0234-6 5.5 amp has a lot more cajones than the 7 amp 0302-20 we have at work ............. suspect it's the gear reduction. Think the ergonomics are better in the older designs; the newer ones are longer and feel nose heavy to me.
  16. renosteinke | Dec 03, 2006 08:31pm | #21
    Bucking the trend here, I cannot endorse Milwaukee drills.
    IN my experience, Milwaukee drills have a few 'design glitches'. These include:
    -A too-accessible trigger, which often leads to the thing turning on at the wrong time- such as when you set it down;
    -A 'trigger lock' that is too often accidentally engaged when holding the drill in your left hand; and, most serious,
    -A tendency, when the bit jams, to either hurt your wrist, or twist you off the ladder.
    Personally, I'd rather have the motor seize up briefly, than lose control when the bit hangs up. I'm not so sure that more power is better than having a clutch!
    As far as drilling efficiency, I fail to see the effect that having 'more power' has ... assuming that the minimum requirement is met.
    Every material has an ideal "feed" (how hard you push) and "speed" (rpm) for drilling it. Since the work takes place at the tip of the bit, this is where tool design has it's effect. As long as the drill is providing "enough" power, it really ought not matter how big the motor is.
    There are three things that DO make a difference:
    - The shape of the drill can either help, or hinder, your efforts to push straight into the hole;
    - The motor size, and its' controls, can make a difference in maintaining the correct drilling speed; and,
    - The motor vents can help to blow chips and dust away from the hole.
    I suspect that, given exactly the same feed and speed, that amp readings of power actually used will be essentially identical between makes.
    Now, there are things you can do to drill "faster," but most of those things will give you a ragged hole and a toasted bit.
    Were I looking for a drill, I'd probably look first at German makes; German tools, again, in my experience, have better 'ergonomics.' That is, they fit your had better, and encourage you to take a grip that will let you use the tool more effectively.
    The second thing I'd look for is a speed control that was easy to read, and set.
    I stress again, though, that the design of the cutting tool is where the greatest difference can be made. If you're using the same generic bits for every chore, you'll never get the results you want.
  17. bubbajames | Dec 03, 2006 08:58pm | #22
    My vote goes to the Milwaukee- I have the 299-30 and it is a monster of a drill! The Newer Makitas (DP4000 series)are supposedly just as good according to a tools of the Trade magazine shootout of 1/2 inch corded drills.
    1. Snort | Dec 04, 2006 01:48am | #23
      When the last bits of smoke fell out of my old 1/2" AEG, I picked up a reconned Bosch 1199...it's great. I have to drill a lot of 4" holes in hardwood, the Bosch has an "anti-rotational" clutch... no hanging up so no more bruised ribs, arms, chins<G>. Works great on doors, too. Oh God said to Abraham, "Kill me a son"
      Abe says, "Man, you must be puttin' me on"
      God say, "No." Abe say, "What?"
      God say, "You can do what you want Abe, but
      The next time you see me comin' you better run"
      Well Abe says, "Where do you want this killin' done?"
      God says, "Out on Highway 61."
      1. CAGIV | Dec 04, 2006 01:51am | #24
        why so many 4" holes?
        1. Snort | Dec 04, 2006 02:50am | #25
          The pancake boxes for ceiling fans need a recessed hole...usta nearly get my arm ripped out of the socket<G> Oh God said to Abraham, "Kill me a son"
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
