Have a Panasonic 15.6v drill model# EY6432. Drill would work for a little and then go off and on and finally stopped working altogether. Took a continuity tester and tested the battery leads on the bottom of the drill and pulled the trigger and showed continuity. What would be the next step in trying to determine problem? Last time I took a tool in for an estimate got the bill for the estimate and ended up throwing the tool away. Thanks for any help.
Clean the contacts both on the batt and in the drill. Check the switch.
Here, I'd go back to my distributor and they would trouble shoot for free, now.....not in a couple weeks. Repair now, if the part was there. Probably give me a loaner if I needed it. I am blessed.
Best of luck.
http://www.quittintime.com/
First check that it's not the battery -- try a different one. Keep in mind that this unit includes logic that will stop the drill to prevent you from running the battery flat. It can be confused by a battery with a dead cell, etc.
Make sure the battery contacts are clean and not bent. The two contacts on the drill side should both protrude out from the wall of the battery socket about 1/8".
Work the direction switch back and forth a few times to see if that changes anything.
It's a one year warranty, so check your purchase date.
A few things.
Check battery with a meter
While trigger is pressed slide in battery
If those seem fine, might be something in the brushes/ armature, any noise at all when trigger is pressed?
“Well, the election campaign in the country is picking up speed... All the candidates are talking about health care now. Don’t they realize that it’s their campaign speeches that makes us sick?†—Bob Hope
How much use has the drill had? If it's a lot, the problem is more likely to be brushes than if the drill is newer.
With intermittant problems it's sometimes necessary to attach temp wires at various connection throughout the circuit to more easily test continuity, voltage, or whatever you like.
Good luck.
FWIW..
I had a Makita 9.2 volt drill that showed the same symptoms. Checking out electrically gave no clue. Finally discovered a small part of a broken paper staple was trapped in the drill body and would sometimes fall into the armature and jam it.
Been working fine since I removed the staple.
