Core bit: How to take apart?
renosteinke | Posted in Tools for Home Building on November 29, 2007 05:54am
I have an SDS roto-hammer, and I use Bosh core drill bits. These bits have three separate parts: the core, the arbor, and the pilot.
I often have trouble removing the core from the arbor. Are you supposed to oil it before you assemble it? Is there a trick to taking the bits apart?
    IMERC | Nov 29, 2007 05:59am | #1
    use never sieze and do you have SDS plus or max???
    WOW!!! What a Ride!
    Edited 11/28/2007 10:05 pm by IMERC
    1. renosteinke | Nov 29, 2007 06:38am | #2
      Ordinary SDS plus. Might try anti-seize. The arbor has extremely coarse, well rounded threads. Usually, I have to keep hitting / dropping the thing until, like a bad baseball bat, the 'ring' changes to a 'duhnk.' Then the pieces separate easily.
      Edited 11/28/2007 10:38 pm ET by renosteinke
        IMERC | Nov 29, 2007 06:41am | #3
        okay it's threaded...
        more than likely you have burrs on the shank / cutter mating surfaces...
        I use never size and pipe wrenches to dissasemle.....
        1. renosteinke | Nov 29, 2007 06:44am | #4
          No burrs. I think drilling dust is getting in. Maybe. Can't grab either piece with tools; the metal is harder than the tools :(
            IMERC | Nov 29, 2007 06:53am | #5
            dust can very easily be yur culpret..
