that’s an expensive way to get a look that’s about as attractive as pre-fab fiberglass.
You don't have to sacrifice historical elements of a house in the name of energy efficiency.
You have to leave a gap around all of the sheets, 1/16" min. You should also have your wallboard 1/2" up from the shower base.But being a certified installer you know all that, right?
HB,
I've done dozens of Corian shower surrounds and find them to look really rich as compared to other single surface materials. Whats important though IMHO is to leave a 1/4" gap or less above the shower pan. When you "silicone" the base to the surround dont totally fill the gap...just enough silicone to adhere the surround to the base. Also , leave a small area ....maybe 1/4" uncaulked in the corners. MAke sure the substrate behind the corian which I'll assume is to be wonder board comes out a bit past he shower base flange. The object is to have any moisture that possibly (but not probably) may get behind the facing will have access with a tiny space and weep holes in the corners....to escape into the pan. this may sound a bit complex but its really pretty simple and effective. same goes for tile .
Have fun
Be well
Namaste'
Andy
It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
overlay the seam with a 10 or 12 inch piece . what kind of shower pan? is this going to be a mud or cement base. if it is mud and tile put the floor in first. then scribe the walls to the floor. the seam will crack with 1/4" mat.
