Cork floor: glue-down or floating floor?
We’re going to use cork for the kitchen in our new house (maybe the living room, too), and are trying to decide between the glue-down “parquet” tiles and the click-together floating floor versions.
Our house is a timberframe (built on a crawlspace foundation), and we’re trying to use materials that will stand the test of time.
We may install this ourselves (we have a good bit of experience with both glue-down vinyl tiles and click-together laminate flooring and aren’t afraid of either). The click-together stuff is easier to install, but will it last decades like the glue-down will?
Which do you recommend?
Leigh
the difference in being involved and committed: chickens are involved in breakfast; pigs are committed…
I can't say anything about floating cork floors, but I installed several hundred square feet of glue down and was/am quite happy with its appearance, ease of installation, and feel while walking on it. Glue down allows for tiny adjustments laterally and you can cut custom trim pieces for decorative edging or design.
I don't know if the manufacturer of your click together flood has beveled edges or not, but they will collect debris. The glue down fit flawlessly (mine was Duro Design) and don't allow grit and grime to settle in. It has stood up well in North Carolina so far against grit, clay, and dog claws.
Installation couldn't be easier. I cut the pieces necessary freehand on my table saw (NOT RECOMMENDED), but you can do it with a box cutter. Back bevel just a tiny bit for a better fit. I also recommend, if available in your brand, the 12" x 24" instead of the square.
i have friends who installed glue down cork that love it. it is a beautiful product.
most people dislike floating floors like laminates (aka Pergo) because of how they feel. the feeling is generally described as "hollow".
i have to agree. i would glue it if i used it.
carpenter in transition
