correct crawl space R.H.%
Bob37 | Posted in General Discussion on March 6, 2006 06:11am
Hello,
We live in coastal N.C. & have a dehumidifier in my crawl space; what R.H. % should I keep it at?? I’ve read below  60% and others state below 55%.  If 60% is good, I don’t want to waste elect. by setting the unit on 55%.
Thank you, in advance, for any help!!!
Bob
  1. davidmeiland | Mar 06, 2006 06:20pm | #1
    Is it not common to have crawlspace ventilation there? Here it's required and having a dehumidifier would be futile.
    1. Bob37 | Mar 07, 2006 04:53am | #3
      Hello,
      Thank you very for your reply; coastal Carolina has unique moisture problems in crawl spaces.  All houses are built on land that was a once a swamp (developers call it "wetlands") so just a few feet below the surface is moisture.  The best way to deal with moisture in crawl space with existing houses is with a dehumidifier.  This is one of the prices we pay for living near the beach where we can play tennis, golf, etc.  365 days/yr..
      Bob
    Matt | Mar 07, 2006 04:43am | #2
    What's more important than the RH is the moisture content of the floor joists above.  9 - 12% is a good reading.  You can get a hand heald moisture meter, but they are a little expensive.   When you buy a termite warranty, that's what they check here in Raleigh - moisture content of the framing.
    1. Bob37 | Mar 07, 2006 05:01am | #4
      Hello,
      Thank you for your reply.  I have a moisture guage and the readings for Douglas Fuer(sp?) are all below 13 and I want to keep it that way; that's why I put in the dehumidifier in my 1.5 yr. old house.  One person suggested R.H. below 40% & that # is way off from what experts say.  It looks like 55% R.H.  will be my target and this will keep the wood moisture in check, as you suggested is so important.
      Bob
