Hi All,
I have several questions that I hope you guys can help me with. I’m re-doing my upstairs bathroom, I have it gutted with only the old tile and mud floor left to be taken up.
Question #1 What is the best procedure to use to remove the old tile and mud floor?
#2 Once old tile and mud is up, what should be done to the floor deck to make ready for mud job? New plywood? What size? Do I go right over existing floor deck?
#3 For the walls in the shower area should I use 1/2″ Durock? Does this get screwed right into the studs? What do I do with the seams? Do they get Taped? What size sheets does Durock come in?
#4 I’m using 16″ floor tile and will be putting an 8″ wall tile (diamond shape). what is the proper procedure for installing the tile? Do I complete the floor first and then start on the walls or vice versa? Is there any specific layout plan for a diamond shape tile or is it laid out like you would a square tile?
I would so appreciate it if someone would take the time to answer all these questions for me. I know it’s alot of questions, but hey you guys are the best, right? Thank you for your time.
John
John, you're right...big questions with not too much space to answer...so I'll start off with this: Look into Michael Byrne's book on tiling. It's a decent source for proper procedures. Second, look on the Tile Council of America's website. The TCA site can be a maze at times, but there is good info there. You may also want to send away for their spec booklet.
That said:
You're using large tiles so the work will go quickly. Will the large tiles be in scale in a small bath? With the larger tiles I'm assuming large grout lines, so use sanded grout. What's sanded grout? Get the book. Grout techniques? Get the book. Modifies admixes in the thinset? In the grout? Get the book. Consider some sort of ribbon across the wall, or a border on the floor to break up, or compliment the diamond pattern? Get the book. Have you considered adding an electric radiant mat under the tile, in the thinset?
Remember, plan on a good floor height transition from the bath floor to whatever room is outside the bath. A marble tranision saddle will help disguise a small transition...but you don't want to be stubbing yout toes.
"...but hey you guys are the best, right? Thank you for your time." Most guys here know that I'm actually a grocery bagger at a nearby store who hangs out on construction forums, but you're right...I am the best. I was awarded "Bagger of the Month" for February....so to be sure of what you're doing...
Get the book.<g>
Here's a link to Byrne's book: http://www.taunton.com/store/pages/070209.asp
Regards, Mongo.
ps, there's a special on avocados today.
Edited 3/26/2002 11:52:32 AM ET by Mongo
I found Brynes book to be great. He explains the procedures in depth and most importantly explains why you do things so you can learn how to apply it to your situation. You have enough basic questions that you need to fully understand what you have and how to to do the job before you jump in. Having the thinset troweled on is not the time to realize you should have figured out how to cut and fit properly before you started.
With it, I tiled several floors and a kitchen. I sold the house to a couple whose family ran a tile business and it was a good enough job that they looked astounded when I confessed I did it myself and asked if I wanted a job.Mary
Gardening and remodeling in Zone 6, MD
Thanks so much for your insight. I do have a question. On the seams of the subfloor, what do I use to fill them?
John
John,
For a subfloor, what Pete said...I'd use T&G ply. No seams to fill.
You definitely have to get and read the "Handbook for Ceramic Tile installation" from the TCA... It's the bible, will address several of your questions, and only costs a couple of dollars. It's definitely the best couple of dollars I've spent in a while.
Besides, M Byrne seems to always revert to 2 major pieces of advice... 1) Follow the TCA guidelines, and 2) follow the manufacturers installation instructions.
Good Luck.
Mike
John, you might try searching the John Bridge Forum.View Imageup-north attitude...
I did a diamond layout in my first shower floor and found that a tile border set square with the shower walls lets you make adjustments so that the diamond arrangement comes out even and equal on all sides. The border tiles get cut so that the diamonds are full or half tiles only.
