correct tip for spraying
kt82 | Posted in Construction Techniques on March 25, 2009 07:14am
I am going to paint my mdf cabinets with Impervo alkyd.
I have a 3200psi spraytech
What is the correct tip?
  1. ckorto | Mar 25, 2009 02:38pm | #1
    Graco makes a fine finish head that uses different tips.  Great for spraying oil and preventing runs.  Sort of inbetween a airless and a HVLP.
    Chuck
    1. kt82 | Mar 25, 2009 03:01pm | #2
      I will check on that . thanks
    BarryE | Mar 25, 2009 03:05pm | #3
    3200 psi could be a few machines, usually they are sized by gpm and model number which determines the maximum orifice tip you can use
    With oil paint on cabinets that shouldn't be a problem, I would probably use a fine finish 311
    Barry E-Remodeler
