How do I clean existing copper pipe joints that a plumber left unclean when he soldered it? (flux was left on and it looks all green, flaky, and corroded)
Choose the right WRB product and install it well, because if you're not keeping water out, nothing else matters.
denatured alcohol followed by hot soapy water will remove the flux
your description sounds like the joints were overheated with lots of oxidation - ferric chloride will make quick work of the oxide, as will most commercial copper cleaners.
If you have a digital camers, can you post a pix of a typical joint.
I don't have a digital camera. But I believe you are right in your answer. The plumber in the story who left the flux on the pipe was me five years ago. :-/
-Chief of all sinners
