Corroded GRK’s
LittleItaly | Posted in General Discussion on August 31, 2007 02:53am
I replaced a 6×6 pt post on a trellis built one year ago.  There were massive cracks and twisting, etc.
More of a concern to me was the state of corrosion that the GRK fasteners were in.  The “climatek” coating was gone and the alloy was already corroding!
Has anyone else noticed this?  I really like the convenience and strength of the fastener, but if this is what happens in pt, i might have to go back to galv lags.
    McDesign | Aug 31, 2007 02:56pm | #1
    <state of corrosion that the GRK fasteners were in>
    Oh #### - don't tell Piffin!
    He's like, their major shill!  we don't want HIM having a crisis of confidence!
      IMERC | Aug 31, 2007 07:45pm | #5
      the time to stop using ACQ/PT arrived a long time ago....
      people are gonna die...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
        MarkH | Aug 31, 2007 07:50pm | #6
        Isn't it about time for the deck collapsing to start?  Fasteners have gotta be getting ate up by now in that stuff.
        1. DanH | Aug 31, 2007 09:10pm | #8
          Nah, they burn them down deep-frying turkeys before they fall down.
      2. rez | Aug 31, 2007 08:23pm | #7
        Timberframe techniques need to be adapted to decking.
        be down with the screw
  2. Hackinatit | Aug 31, 2007 03:20pm | #2
    I'm about convinced to use sealed, NON-pressure-treated on any outdoor project. This fastener/hardware corrosion is plain scary.
    Troy Sprout
    "A free people ought not only to be armed and disciplined, but they should also have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
    -- George Washington
  3. JTC1 | Aug 31, 2007 03:46pm | #3
    That's why I don't trust anything but SS in PT.
    More $$ but peace of mind.  Clients don't complain once the situation is explained, maybe I'm lucky but a rational discussion before the project has always "sold" the additional expense of SS fasteners.
    Universal Forest Products, Inc. is selling something called "Pro Wood Micro" through the local HD - not at any of the local pro yards (yet?).  This is a PT, SYP product.  Treated with Copper Quat.  Their website claims corrosion rates for steel (brights) which falls between KD and CCA.  This makes HD galvanized fasteners a viable alternative to SS.  They post a number of corrosion tests and compare rates in KD, Pro Wood Micro, CCA and ACQ.  I'm going to start my own little corrosion test.
    I love GRK screws, but use their SS product line in outdoor PT.
    Jim
    Edited to correct manufacturer's name - I had ""Forestry" rather than "Forest".
    Edited 8/31/2007 9:01 am ET by JTC1
      McDesign | Aug 31, 2007 04:42pm | #4
      <I had ""Forestry" rather than "Forest".>
      Yeah, you wanna' get that right -
    2. BillBrennen | Aug 31, 2007 09:18pm | #9
      Jim,Your post is timely, as I await a return call from salesman for $1K of GRK stainless fasteners for exterior service, much of it into ACQ'd wood. Your experience supports my initial prejudice that Climatek coating is no match for the corroding power of ACQ. Thanks.Bill
      1. Piffin | Aug 31, 2007 11:32pm | #11
        I didn't realize you were looking at ACQ for your project. Definitely the SS GRKs!
        1. LittleItaly | Sep 01, 2007 02:31am | #12
          Thanks for all your input guys.  I suspected that stainless was the direction I needed to start heading.
          My fear;  Over the last five or so years we have almost exclusively used GRK's for fastening posts to outside framing of decks.  Can't wait for the recall work on that!
          I will be taking back the GRK's I removed yesterday to our supplier and see if they have had any feedback as well.
          1. Piffin | Sep 01, 2007 06:02pm | #18
            For thazt sort of application, you should not be using screws of any kind anyways. That is a design location that would require bolts, not screws.
  4. Piffin | Aug 31, 2007 11:30pm | #10
    you need the stainless steel GRKs
      IMERC | Sep 01, 2007 02:51am | #13
      time to use other than ACQ....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  5. hvtrimguy | Sep 01, 2007 06:00am | #14
    oK - stupid question - whats GRK stand for?
    another note - I have a piece of aluminum I took off an ACQ 4 x 4 that all but turned to dust. holes in it and everything. only 1 1/2 yrs old. Glad I haven't don a lot of work with ACQ lumber. I don't sleep much as it is.
    "it aint the work I mind,
    It's the feeling of falling further behind."
    Bozini Latini
      MarkH | Sep 01, 2007 02:51pm | #15
      Green River Killer.
    2. BUIC | Sep 01, 2007 02:55pm | #16
        GRK is a brand of high quality screws.  buic
        http://www.grkfasteners.com/
      Edited 9/1/2007 7:57 am ET by BUIC
      basswood | Sep 01, 2007 04:21pm | #17
      --"I have a piece of aluminum I took off an ACQ 4 x 4 that all but turned to dust. holes in it and everything."What you have there is galvanic corrosion (corrosion of dissimilar metals--actually resulting from a miniscule flow of electricity between the metals when wet). Aluminum is bad in combination with the Copper in ACQ (same issue as common steel and ACQ).The best flashing choice for ACQ is Copper.Also, get your hands on some GRK screws and I bet you will like them, good stuff.
      1. hvtrimguy | Sep 03, 2007 03:08am | #20
        I think I will try the GRK screws, I like star drive's in general."it aint the work I mind,
        It's the feeling of falling further behind."Bozini Latini
      Sphere | Sep 01, 2007 06:08pm | #19
      It is the sound they make just before they snap, hear that sound, let off the trigger.Spheramid Enterprises Architectural Woodworks
      "If you want something you've never had, do something you've never done"
