corrugated metal walls
Wooddust | Posted in General Discussion on May 22, 2007 07:45am
Considering corrugated metal galvanized for walls in a bathroom and as a backsplash in cabin kitchen. Have any of you ever installed any and how did you cut it to fit?
Any thoughts or cautions?
  1. TomT226 | May 22, 2007 08:40pm | #1
    Built pole-barns and other structures with it, and the Metal Mart colored metal.  Use a skill saw with a metal blade, or turn a regular blade around.  Get some good straight cut snips to make your switch box cut-outs.  Wear goggles, gloves, and ear protection.  Make a cutting box out of 1X6, 2' wide, 4' long with a brace in the middle.  You can lay the metal on the box using that as a support and a sacrificial table when cutting sheets.  If you have a Metal Mart in your area, they'll cut it to length for you for a small charge.
Two Ways to Test Windows
  • The New Old Colonial
